Air mix control motor
babsbarnes
Car: 1993 J30
I have a 1993 J30, that the air mix control motor is not working, anyone know were to find the part?
driverdriver
Car: NICO's longtime resident Canuck!!!
The actual heat/AC unit on the dashboard?
babsbarnes
Car: 1993 J30
no it's actually located under the dash above the gas pedal,
it is what controls the difference between heat and cold
the part would have to be used, because the manufacturer no longer makes it
driverdriver
I'm not familliar with it.
See if this helps you?
http://fuzzycats.com/j30parts/page_756.jpg
goody90q45
Car: 1992 Infiniti Q45 (sold)
Your J30 is going to be similar to the Q45 and I've had this problem in 2 of my Q45's. In both cases it was the door stuck in the closed position the first time I asked for heat after the long summer. f you haven't already, remove the mix motor and test it with a couple of probes connected to a battery. While the motor is out exercise both doors manually. If the motor tests good chances are it will work when you reassemble the motor to the air box.
