piratepete wrote:How would the temperature change anything? It's a MASS air flow sensor. After the intercooler there would be less volume of air, but the same mass.
ziggy682 wrote:With a draw through setup, if you run an open atmosphere blow off valve, the car will run rich when the bov vents.
Also, you can run an open atmosphere bov before the MAF with no ill effects.
ziggy682 wrote:Your ECU adjusts timing and fuel delivery partially based on intake temp. If the MAF is before the turbo, then the engine will get hotter air than it thinks it's getting. Because of this, timing and fuel won't be optimal.
C-Kwik wrote:You seem to contradict yourself here. With a draw through set-up, an open BOV would not have any effect if the BOV is before the MAF. Running it after the MAF would have the same effects of running an open BOV in a draw through set-up.
C-Kwik wrote:Yes, but as long as the hotwire is at a higher temp then the air going through it, it will account for the density change from temperature differences. the heat the air takes away from the hot wire is a direct function of how many molecules of air pass around it. The more molecules there are in a given volume, the more heat it will take away. A hotwire MAF is about the single most accurate way of metering how many molcules of air are entering a motor. To be more accurate with other systems require more sensors to account for changing conditions. For this reason, there should be no difference in the voltage between a blow-through or draw through system assuming of course it is getting a proper reading.
ziggy682 wrote:I don't think you read my post clearly. I didn't contradict myself. I was refering to a blow though setup in which you can run an open atmospere blow off valve with no ill effects as long as it's placed before the MAF.
I don't think it's possible to place a BOV before the MAF in a draw through setup. If the BOV is placed before the turbo, it will not blow off, it will suck air in, because it is in a vacuum. The blow off valve will only vent air if it's placed after the turbocharger, where the air is compressed.
ziggy682 wrote:Again, I don't think you understood me correctly.
In an NA car, the air that passes through the MAF will be close to the same temperature when it enters the engine.
Imagine if you turbocharge a KA, and don't use an intercooler. If the MAF is placed before the turbocharger it will read ambient air. Let's say 75 degrees. When that air is compressed by the turbocharger, let's say it heats up to 250 degrees. In a non-intercooled system, the engine would injest 250 degree air, but the ECU would only think it's getting 75 degree air. Therefore, fuel and timing won't be optimal for combustion at that temperature.
If the MAF is placed after the turbocharger, than it will read 250 degree air, and the ECU will compensate correctly.
In an intercooled system, the temperatures would drop dramatically, but it would still make a difference.
Also, I understand that an MAF measures the mass of air, and takes temperature, density, and such into consideration. The engine will always get the same mass of air that the MAF reads(unless you have a leak), but the ECU will adjust timing parially based on intake temperature. I think, in a blow through setup, it will be more accurate because intake temperature will be read correctly.
C-Kwik wrote:Actually I read it very carefullly. You stated:
"Most people put the MAF before the turbo because that's where it's commonly placed. It's called a draw through. With a draw through setup, if you run an open atmosphere blow off valve, the car will run rich when the bov vents."
A vehicle that runs an open BOV anywhere after the MAF will cause it to run rich if the BOV opens. It would not make a difference if it is draw through or not. But if you placed it in front of the MAF on a draw-through set-up then it would not know any air was released. You stated above that it would run rich with a draw-through set-up and then later said it would have no ill effects. So you did contradict yourself...
Though I did state the wrong thing in my post. In a blow-through system, it would not have an effect on the fuel mixture. I think I do know you were trying to state this, but your post had a small contradiction. It didn't help that my correction had an error though. =):pface
Turbo 510 wrote:A BOV vented to the atomosphere will make a vehicle run richer because air is being released from the system. Since fuel in injected at the port the amount of air reaching the port will be less than if the BOV did not open. Also, why would anyone place a BOV before the turbo? it is meant to release the reversion wave that is caused by slamming the throttle plate shut. This wave, unchecked (or vented) goes back into the turbo outlet and over time will damage the compressor wheel and/or the bearings shaft,etc. The BOV should be vented back into the system after the MAF but before the turbo. This keeps the same mass of air in the system. I have never heard of anyone putting a MAF after the turbo, but it would seem to cause a bunch of problems. Maybe I'm just out of the loop on the type of set up.
