Ok thanks! Yeah I've seen it and I've cut the bottom off of it, but I just want the whole thing out now, and wasn't sure how to remove it.After cutting the bottoms of it off, I did noticed a tad smoother/quicker acceleration, so I'm hoping taking it off altogether will help even more.Turbogst wrote:go to the drivers side take out the fender liner(the black plastic in the wheel well). unbolt and take out..
Doesn't do a bunch, some people say it drives a lil smoother and it's a lil louder. can't miss it . It looks like a big a** square milk jug
yup thats what i did.... except i used plastic flex hose by spectre (at any corner auto store like kragen or autozone) its more of the right diameter dryer vent is kinda wide (4" diameter) but it works tooTurbogst wrote:you can also go to home depot and get some dryer vent hose and run it from the front to the bottom of the intake where your filter is for a ram air set up. I'm going to try this with Pvc and a sheet metal box made to collect the air.
Fueler if you don't mind can you post up some pictures and does this reduce/improve fuel economy or makes no difference.fueler wrote:
