Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Mar 14, 2006 3:06 am
The ultimate intake:
Cut a round hole in your hood, then turn the plastic intale hose vertical. Mount the MAF on the end, and stretch a piece of screen door across the end with a tywrap.
This may net you 200 to 300 rear wheel HP, easily!
No really, I ran the Stillen POP charger on Layla for about 150,000 miles. I didn't see much difference, but I did not box it in, insulate it, or modify the ducting you are talking about.
I believe my mileage increased some, due to warmer intake temps, and it really sounded mean when I got on it.
The issues were the K&N oil drove the MAF nuts and I had to clean it often.
If you think there is a restriction, then just remove the lower portion of the filter box, and use tywraps to hold the filter to the MAF. I believe Dennis stated it right, ther isn't much gain to be had.
INFINITI designed the intake for quietness, which was WAY more important to the company than HP at the time. They already had the fastest sedan in the market.
If you want to add some fractional HP, then insulate the existing pipe between the MAF and the plenum. That pipe gets hot, and the plastic doesn't do much for heat transfer.
I believe the intake was designed when the Q had no grille, and nobody changed it when they added the grille. The area around the light is a very high pressure area, and not much face area is needed, for adequate air volume to the intake. A lot of cars use this area. The bumper also protects this area from most water splashing.
