trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Thu Mar 13, 2003 6:21 pm
Ok, to answer some of your questions:1) It's mostly heresay that says an intake will give you any kind of noticeable horsepower OR gas mileage increase. Mostly what an intake will do is make your engine breathe a little bit better, but your stock intake system isn't really breathing hard until around 4500-5000 RPM. And even at that level it will probably give you VERY minimal increases, IMHO not worth $200. You probably will notice some gains when intake is COUPLED with exhaust, but either or really doesn't net much.2) NGK platinum plugs are a WASTE OF MONEY ON A STOCK KA. Use what the factory recommendations are. A spark is a spark, in an NA engine as long as it's gapped correctly it doesn't need any more than that. It would be worth your money to buy new factory NGK plugs, gap them correctly, and put on new NGK wires. It's proven to be the best combination. And doing so isn't a power ADDER, it's just bringing your car a little closer to factory specs, I'm tired of people putting "Platinum Plugs" and "Performance Wires" on a list of mods.
