Air intake question
trust068
Car: 1991 240sx SE coupe
I have a question. does aftermarket intake (AEM) tend to make the engine rooms leaner or richer?
thanks
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
I know it will get more air. It should run the same as far as lean and rich. Your mass air should be able to sence the extra air and burn correctly. Does someoone who actualy know what there doing have imput on this.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Should stay the same.
InsanityInc
It'll stay the same until at some point you start maxing out the injectors, but just an intake won't do that.
trust068
I ask this question because for alot of toyota that runs MAF tend to runs leaner with aftermarket intake installed. but thanks
InsanityInc
Are you sure toyota MAFs run leaner, and not toyota MAP-sensor-equipped cars? The advantage of a MAF over a MAP is mostly that the MAF works a lot better with modifications or changing conditions in general.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Most mid 90's and later toyotas had the flapper door maf's. The nissan has the hotwire maf and is much more accurate, will compensate any airflow and provide oem intended a/f.
edit, the toyota ones arent really a maf, but an afm.
trust068
deviousKA wrote:Most mid 90's and later toyotas had the flapper door maf's. The nissan has the hotwire maf and is much more accurate, will compensate any airflow and provide oem intended a/f.
Thanks for correction. the specific car i was talking about is 1mzfe for solara, camry, es300..etc
