air intake installation??
Alastaplat
Car: 1989 240sx
I bought an intake online and it didn't come with any instructions now I'm clueless as to how to install the damn thing, I never realized how many parts there are to installing one of these! but now I do and I don't know how to install it, so I'm seeking help on how to do so... I have a 1992 240sx hatchback. your help in appricated
Eikon
Car: 71 240z, 93 Supra TT
Do you have a link to what you bought.. perhaps they have some pictures of a finished product..
for example..
Basically, you should have a cone air filter. That should connect to the stock MAF sensor. Then another tube should run accross the engine and curve in to the intake manifold. You should have fittings and clamps for each connection it makes, as well as some extra tubes for the pre-throttle body air connections (IACV and AAC). You probably also have a few brackets and other fasteners that help keep the intake in a proper position.
Why don't you take a photo of what parts you have... and we can help you determine how to install them.
wirelessalpha
Car: 93 SR Vert, 96 318ti, 06 Altima
Seth - you're a good man charlie brown.
Hijacker
Car: '92 240sx Convertible
'94 F-150
This has nothing to do with the vert. so it's getting moved.
Eikon
thanks Chi!
I must admit that I jump at the chance to help out with whatever I can. Lately I've been feeling guilty that I don't have the knowledge and expertise that you and 94_240sx and others have on some of the more complicated situations..
Alastaplat
Car: 1989 240sx
here's my engine..
Alastaplat
Car: 1989 240sx
here's a different angle
Alastaplat
Car: 1989 240sx
more engine pics..
Alastaplat
Car: 1989 240sx
even more pics...
Alastaplat
Car: 1989 240sx
don't know if this one'll help..
Alastaplat
Car: 1989 240sx
here are the parts I have to deal with..
Alastaplat
Car: 1989 240sx
are these parts??
180fan
Car: 89 fastback
iirc, that part at the bottom of the plastic intake piping should be a resonator you can ditch that. The other metal hardware with the rubber and the studs pokin out of it are for support at the other end where the filter is.
Alastaplat
Car: 1989 240sx
wait, ditch what?? sorry you lost me..
Eikon
you can ditch the stock resonator tube. The one that you asked about before... the tube that goes down from the bottom of the pipe near the left side of the radiator.. the one that you circled.
it's not a vital part for a higher performance intake kit.
The two little brackets should be for securing the intake in place. Notice in the picture of the red setup on the top... on the radiator fan shroud there is a little red bracket... that should be one of the two little metal brackets. Those are there to keep the intake from bumping around and coming loose.
Once you start taking the old one apart and test fitting the new one... the peices will fit together and it will make more sense.
Let us know if you need more help.
Alastaplat
Car: 1989 240sx
ok so what am I going to do with that hose the that I don't need?? just take it out? or block it?
180fan
Car: 89 fastback
The hose you don't need? Assuming there isn't an opening at the bottom of that new pipe you got for your intake kit, here is what you do.
1. lift your old intake parts over your head2. run screaming towards the corner of your garage3. heave your old intake parts into that corner4. stand and take a gander at how marvelous those plastic parts fit in the corner of your garage.
In the event you do have an opening at the bottom of that new intake pipe, block it off.
TougeMS13
Car: '91 coupe
Maybe its my new meds, but for some reason I immediatly pictured a midget running through a garage with an intake over his head screaming like tattoo....strange.
On a side note, not sure how emissions are in PA, but save everything you pulled out since in case they dont pass you on visual.
180fan
Car: 89 fastback
^^ rofl
Alastaplat
Car: 1989 240sx
is that a picture of your intake that you posted??
Eikon
Alastaplat wrote:is that a picture of your intake that you posted??
Nope, just a random one that I found on the net.
Did you install your intake yet? C'mon already... we're all getting impatient.
lol
Alastaplat
Car: 1989 240sx
no I haven't yet and I'm getting pissed too... makes me feel more stupid every minute that goes by that I can't get it.... this is what I get for buying a cheap one I guess... now I have to impervise a bit then I'll be able to get it I think... I hope is more like it lol
Eikon
Ok.. let's sort this out so that you can get it installed and be happy again.
Sounds like your last question is regarding the tube that drops from the intake tract just after it curves past the radiator.
Did you inspect that tube to see where it goes? I think you'll find that it's a dead-end. Most factory intake tracts have resonance chambers. They are just dead ends for air pulses to bounce into when they reverberate off a closed throttle body. It will have some benefit in quicker throttle response for a stock intake system, but the gains of a low resistance aftermarket intake setup will far outpace the loss of this little chamber.
I can get into more detail if you want... but rest assured... it's not needed. Your intake system has all the parts it needs and will work just fine.
Look.. I've been in your shoes before... Heck I'm still right there... I'm not confident enough to take on the project until I've fully researched it and made sure I know what I'm doing. That's good... but on the other hand.. you'll never get anything done, and you'll never learn everything you need to. Sometimes you just need to dive in and figure it out.
Find a couple hours of free time this weekend and start working. Unscrew the couplers, unbolt the brackets and start taking the intake system apart. Then put the replacement parts back on. It'll be like a little puzzle.. but very easy.. You'll see how they piece together... it will make sense.
if you have trouble with it... take a photo and post it up... We'll help you out.
Like Nike... Just Do It!!!!!
hatchback240
Car: 1993 240sx
yo, thats the AEM short ram right? i have it on my car, hook me up with an email and i'll hook you up with the instructions- complete with pics
mrzabala
Car: 93 Nissan 240SX SE Hatch
My K&N cold air fitler came with a tag that passes smog visuals. So keep your stock parts b/c you may need it. As for the tube to the resonator that goes down and is bolted onto the shroud you can take that out and store it. You wont need it when you install the egay kit. I dont know why you wont just go through it. Some of us are here to help you if you get stuck so just go through with it, its more straight forward than it seems.
180fan
Car: 89 fastback
Pictures are worth a thousand words. Anyone feel free to correct me if any of that is wrong in the picture.
Alastaplat
Car: 1989 240sx
my email is [email protected] make the subject obvious, cause I get a bunch of **** mail and I tend to delete anything that looks not important
