Study the turbine in a radial supercharger, turbo, or axial unit
In no design can you see thru the fan blades............electric blowers are speced in inches of water column pressure: 1 " of water is 1/28 of a psi.
Remember the engine is already supercharged by the earth's atmosphere. "The [EVERY] engine is already under 14.7 psi of positive pressure, something everyone forgets!
"The power required to drive the compressor is a lot more significant than most people realize. As an example, for a supercharger (turbo or mechanical) to deliver an additional 100 horsepower of air to a given engine -- say a typical 350 small-block at 5,000 rpm -- that supercharger will require anywhere from 25-35 horsepower (depending on the efficiency of the compressor itself ."
EACH HP requires 746 watts to create [plus electric motor inefficiencies]. SAY 900 watts to be safe.............0.9 x 25= 22,000 watts
http://www.turbomagazine.com/tech/0406tur_knight/
Pretty hard to even bend the laws of Physics............. with marketing lies.
