AIR IN SYSTEM Replaced RADIATOR and THERMOSTAT
juicehustlin
Car: 2008 M35 Infiniti
So I noticed that my radiator was leaking coolant the other day, so I immediately stopped driving my car and replaced the radiator and thermostat over the weekend. My car is now overheating once it warms up, and I touch the lower bottom hose and it is cool to a touch. So the thermostat is not opening up, and I'm thinking it is because I am not bleeding the system right. How do I bleed the system with the bleeder valve? Do I just leave it open while the engine is running and the radiator cap on, until it starts streaming out coolant with no bubbles? :confused:
Ilya
Welcome to the forum.
Check this thread, I think it has the info you need:
post6685736.html?hilit=bleed%20coolant#p6685600
juicehustlin
Ilya wrote:Welcome to the forum.
Glad to be here! Thank you so much! Will try this this weekend, and report back hopefully good results! Thanks again :mike
juicehustlin
So, did the steps and now i'm seeing coolant dripping out the exhaust right where the catalytic converter connects. What could this be? Any help is appreciated
Ilya
The front of the cat or the back? If it's the front, it might just have come out of the line at the back of the motor where I believe the breather is and run down the pipe? I wouldn't think it would be IN your exhaust.
juicehustlin
Front of the cat. I'm hoping so, I pray it's not a blown head gasket
