Air Fuel Ratios are bad!!
TeamTorqueJuggernaut
Car: 90 Nissan 240sx
Ok, I just installed my AEM wideband. While crusing around im only reading between 16.5 and 17.9. At wide open throttle im only getting about 13.5 and this is on stock boost. Im just thinking is there something wrong with the wideband or is my car really running this lean. I have a warlbo 255 pump, a untuned safc, I do have HKS 264 cams and a megan racing manifold. I just had all the leaks in the exhaust closed up before I put the wideband in but I wouldnt think that would mess with the a/f ratio. Ive been driving this car for about six month and have run up to 13 pounds at times. I would think I would have blow it up by now but any help would be appreciated.
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
well why dont you tune your safc
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Its because You have a stock Fuel Pressure Regulator ...Right? And you blow a motor by running it too lean, Too rich is safer than completely blowing it but you loose power and too rich you can flood the cylinders and contaminate your oil by fuel seeping past your rings and thats if you dont completely wash the rings off the pistons and the fuel in the oil can wear your barrings out real fast!!! (KNOCK KNOCK KNOCK KNOCK Time for new complete rebuild) Go pull your dipstick and smell for gas & Do us all a favor n buy a aftermarket FPR because I dont wanna see a post that any of this happened to any1 WHO'S YOUR BUDDY... ....? Im YOUR BUDDY !!!!!!!!!!!!!!
Modified by supreamS14 at 1:34 AM 3/28/2008
RPS13 DRIFTER
Car: S13 Hatch SR'D
if you have 650cc injectors and a ECU tune would you need a aftermarket FPR?
supreamS14
Damn I was retarded last night, 16 and 17 is lean isent it?
srdub-t
yes the higher the number the leaner your running, and no you dont need an fpr for 650cc injectors.
srdub-t wrote:well why dont you tune your safc
Well I havent put any setting on the Safc due to the fact that I thought at WOT the air fuel ratio would be in the 11s or 12s and riding would be in the 14s.
srdub-t
rinding around under light load 16s and 17s is fine, but just tune your WOT to like mid 11s
S13NismoStyle
Car: 1993 Nissan 240sx Fb
Juggernaut, i had the EXACT same problem with my sr. same afrs and everything. i still havent figured out what the problem was. here is a link to my tread and maybe it can help you out.
zerothread/321581
i ended up just adding more fuel with my safc, but i believe im going to have to upgrade my injectors to keep up with the added duty cycle.
