Air/fuel ratio wire @ ecu?
Turboed240
Anyone know which wire I can tap into at the ecu on an s13 redtop for an autometer air/fuel ratio gauge?
Oneor1
Car: cars, music, hockey
You need to tap into the Oxygen sensor wire comming out the exhaust manifold.
Rick Johnson92 coupe
Gmans13
what wire. My o2 sensor has 3 wires red white and black. Let me know. Thanks
I too have a s13 redtop
battle D
Car: drifting
let me know also, and u can connect it to the ecu cant u mine is connected to the oxygen sensor and tis not working its a very dim red but i need to figure out how to hook it up to the ecu
Tartan
Car: 89 240sx
I had that same problem when I had one...I heard that the autometer gauge isnt compatible with the o2 sensor on a red top.
Gmans13
why would it be any different with an auto meter gauge and a different brand. Don't they all do pretty much the same thing? I don't have an autometer gauge but it sounds the same to me. 3 wires. one power one ground and one that goes to the o2 sensor. I'm going to look in to the wire colors to see if I cant just splice in to the main harness next to the ecu. I'll let you guys know.
battle D
Car: drifting
why wouldnt it work i ahd my first swap done at unstalbe hybrids adn they give u a vdo boost gauge adn autometer a/f gauge adn it worked fine but i dont remember where it was connected
Gmans13
hmm...do you still have the car? If you do you should run outside and check for me.
Gmans13
does anyone know where to find out what colors all the wires are in the harness. I've looked at it before but I cant find it. Thanks
Gmans13
http://www.nissaninfiniticlub....47985
