sr kid 88 wrote:ok so i just had my motor fully built from sleeves to stage 3 bc cams. ne wayz i was running emanage ultimate and that wasn't cutting it so i got a flashed jim wolf ecu programmed for my setup. when i first started it up the air fuel sat on 14.7 then worked its way down to mid 11s i wanted to know if that is where the air fuel is supposed to be at on the jim wolf and might i add it smokes white as it get richer(around 10s and 11s) anybody have a answer. thanks
no, thats way rich, it should stay around high 14ish all the time at normal idle.
