compression »
https://forums.nicoclub.com/compression-u9345.html
Wed Aug 30, 2006 11:33 am
As virus77 said...stock oxygen sensors are basically a switch and you are either rich or lean, how much rich or how much lean? it doesnt know because its stupid.
If you want to see your true air/fuel ratio, you need a whole wideband kit, like the AEM or Innovative one, and expect to pay $200 to $300 for it. It will include a new oxygen sensor (with 5 or 6 wires coming from it) that is a heated sensor.And your stock ECU will still need the signal from the stock oxygen sensor, so you have to leave that in the pipe and add a bung for the wideband, so you will have 2 oxygen sensors. One narrow band for the ECU and a wideband for your AFR gauge/datalogger/whatever.
