rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Fri Sep 29, 2006 5:20 am
Well, the CA runs very rich from the factory for starters. Early 90s Jap tuning is based on as much fuel as you can get into those little cylinders. Another issue common to older CAs is the FPR goes out. Also, make sure that you have no vac leaks. Could be timing, yes, so check that as well. How are you basing this judgement? Do you have a wideband?
And seriously, turn caps lock off bro. It is very annoying, and in the world of the internet, all caps is the same as yelling. Don't yell at us. It is rude
