air/fuel ratio gauge
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
hey guys. i got one basically cuz it looks cool lol. i like seeing what's up w/ my engine too of course :thinker
but anyhow, it's an autometer ultra lite 2 1/16" gauge...what do i hook it up to? lol
there are 3 wires, 1 red 1 black 1 purple...the red and black are power of course...the purple goes where? i'm a bit confused
im not as much of a noob as i sound, i'm just tired and dont feel like explaining in detail...
HOW DO I PUT IT IN? :confused: lol
redtop sr20 btw
180fan
Car: 89 fastback
black = groundred = any switched power source like the line for your stereopurple = taps onto your o2 sensor at ecu or anywhere along that wire.
MainEvent212
yea, i got that far, i'm thinking either the wrong wire is tapped or the gauge is bad...the guys at my shop put it in while they had my car...can anyone point me in the direction of which wire on the ecu it is?
quiksilvia
Car: 95 s14 se
search nico for that online fsm and check that out, or follow the wire coming from the o2 sensor
S13240
I couldn't get my gauge to work so I gave it to my friend for free. I just bought the LM-1 a/f ratio gauge(wideband) yesterday from LS Auto.:D Can't wait to install it and then start tuning my afc-2.
MainEvent212
hm, if u got a stock SR i doubt the AFC is gonna do much..but that's just IMO
S13240
I have basic bolt ons. It's a good universal tool to have to know how the car is running, accurate when tuning. Better than the autometer a/f ratio gauge.
MainEvent212
lmao well yea...the only reason i really wanted this was for the light show...i'm not ashamed...i like flashing lights :rolleyes
MainEvent212
MainEvent212
so i've decided i have a bad gauge...going to return it tomorrow
DriftS14
I'm sure yours is doing the same a mine. It looks as though it doesn't work, but I doubt you and I both got a bad one. I am going to test each of the wires coming from the o2 sensor and try tapping into those as opposed to connecting it at the ecu. I'll let you know A.S.A.P.
MainEvent212
no, it just stays on the furthest rich LED the whoel time, never changes...even when the car is off
DriftS14
does it flash at least?Cause mine flashes, but stays on the same green led the whole time. Looks like its trying to do something but not.
Cyberkreig
Car: 1993 Nissan 240SX SR
that document looks mostly accurate.. except line 23 G/R is one of the 4 wires required for CONSULT
Phax
Car: Control dynamics
MainEvent212 wrote:lmao well yea...the only reason i really wanted this was for the light show...i'm not ashamed...i like flashing lights :rolleyes
:withstup
Flashing lights are goodness. The A/F gauge is the first thing that anyone comments on when they get in the car at night. All of my stoner friends like it because it gives them something to stare at. One of my buddies even has a chant, "Blue, blue.. make it blue!!" Because he likes the bright blue LED glow of rich, WOT.
S13240
LoL, I can't disagree with you on that because I like the flashing lights myself. Although all mine did was stay green everytime so I gave up and gave it to my friend. I thought it was the gauge too, but as soon as my friend installed it onto his civic...it was a light show! :eek:
MainEvent212
mine dosent even blink...it just stays a constant green led on full rich...i'm taking it back tomorrow...:(
light shows are sweet :ylsuper
quiksilvia
Car: 95 s14 se
pothead ravers.... :)
Cyberkreig
quiksilvia wrote:pothead ravers.... :)
So?
quiksilvia
Car: 95 s14 se
lol, we are siiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiick
Phax
Maybe in 1996...
MainEvent212
ok, so update...the gauge was NOT broken, i returned it and got a new one, same deal...the shop put it in wrong i guess...i gotta figure out where to connect the purple wire now :-\
MainEvent212
hey phax, since yours is working...where did you hook the sensor wire to?
NY S13 SR
For Autometer gauges, if the wires are hooked up right, the solid single green means it has power but no signal. Totally dark means no power or signal out of range. I have seen several that work but seem to be out of the range, sort of shooting across the whole gauge sometimes off on the red side totally for a while.
The one in my car works perfectly, very useful for testing Z32 MAF sensors, I can spot a bad one in 5 seconds.
MainEvent212
well where do i hook it to? right now it's hooked up to the ECU and i'm not getting any signal...i'm gonna try to reattach it..but maybe it's the wrong wire?
i'm fairly sure it's correct though...help :(
NY S13 SR
Maybe your O2 sensor is bad or not getting 12v or bad ground. Check those out, do you get bad gas mileage?
________________Jeff HHeavy Throttle
MainEvent212
lmao yea i do...it's really just an unfixable issue...called lead foot :pface
but yeah, the guys at my shop are idiots and tapped the wrong ecu wire...my gauge was trying to read the TPS input :rolleyes
gonna ***** them out tomorrow
Phax
They tapped your TPS to try to get an A/F gauge to work? Huh? I have a Bosch O2 sensor. I tapped the white wire for the signal for the A/F sensor. The other two were red and black, and go to what you'd expect red and black to go to (positive and ground).
MainEvent212
they're right next to eachother so it was an accident...but still :rolleyes
stumpz
lol we have different o2 sensors than what they are meant for...we' have narrowband, they are meant for the wideband..(off top of my head..);therefore, they give a very inaccurate reading.
