Air Fuel Ratio Gauge Install
TheDrumAndTheBass
Well, now that I am almost done changeing my head gasket, I will soon be installing a number of gauges to help monitor the status/health of my engine. The first of these will be an Autometer air/fuel ratio gauge. If anyone out there has installed this specific gauge and could help me figureing it all out I would appricate any info I could get. I'm buying this gauge from a friend of mine that was going to install it in his RX-7, but now is into morotcycles. It has never been used, but we can not find any trace of the instructions. O yeah, and it's going in a 89 KA24E if that makes any large diffrence.Ryan
Just another 240
u know i would have helped you if i stole the gauge from autozone..but i didn't...so can't help you.lolz
TheDrumAndTheBass
Ha, I didn't steal the gauge from Autozone either. In fact, I didn't think they carried Autometer gauges at Autozone. I just know my friend I got the gauge from, originally bought it from Summit.
Just another 240
u know i sometime think i should have stole it..becuase if i don't..someone else would..comeon it's autozone! lolz...but then i dont' wanna risk it for a 50buck gauge..anyways...how many wires and stuff is on the gauge, maybe i can help you by describing it..
themadscientist
how many wires and what colors?
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
usually with A/F meters, theres 4 wires, one to the o2 sensor (green?), one power (red), one ground(black), and one to the lights (white?) ......am i correct?
-Dan
themadscientist
the yoyo autometer one has three I think; black(ground) White(ignition hot) and purple(signal from O2)I've had two in my hand and the marbles are a litlle loose in the head so i might be mistaken.
slow s13
Car: cars, photo, music
I just did an autometer one and purple is the O2 wire if it has a white wire it is ilumination. red wire is b+
fiznat
Car: Grown up :(
theres a DIY about A/F gauge installs in the FAQ/DIY stickey on NICO General...
Dano
so yeah i was right, but here's revised..:
Red wire-Power (duh (but sometimes white)) to 12volt sourceBlack wire- Ground (duh) make sure u ground well!White wire-illumintation (pretty common) u can connect to interior gauges or dim switch...Signal wire- other color (usually blue/ purple/ or green) to o2 sensor
-Dan
Dano
o, ****, read fiz's post, we posted at the same time
-Dan
S13240
I've had a problem that I still can't figure out about my autometer a/f ratio gauge yet.
When I turn my key to on the red led would light up on the gauge and when I turn on the engine the gauge's led would flash up and down quickly in the stoichometry/ideal area of the gauge and just die like there is no more power coming to the gauge? What do you guys think what could be the culprit?
SilGuy
so which color is the signal wire on the 240? Thats all you need to know. On most of the generic a/f gauges, u just need to know tthe color of the signal wires on the gauge and the o2 sensor. The other wires are misc.....
S13240
Ok I finally solved the problem today, but it seems to be showing that I'm running really lean. I had a bad ground so I had it grounded to the engine, same place as where I have the negative terminal from the battery hooked to near the throttle body.
SloS13
the o2 wire is white and located above the 10mm harness bolt if i remember correctly. If its showing lean, that COULD mean that there's not a good connection signal wire/gauge wire, so make sure its soldered or you wont get an accurate reading.
my ****s rich as hell, while im crusing, it doesnt even bounce around it just stays green :(
