Unless the stock fuel pump is running at maximum output there is no need to upgrade the fuel pump with the listed mods.Chaotic_Warlord wrote:Now I am thinking of installing a 255lph fuel pump, an adjustable FPR, and larger injectors and a Z32 fuel filter. I would also like to upgrade to a ram-air style intake and possibly a MAF upgrade (which would mean I would need a tuned ECU, which I don't want to get until I go to install the turbo).
Stock. You will be supplying more pressure. Adjust pulse width to regulate flow.Chaotic_Warlord wrote:My questions are:
- If I were to upgrade to an aftermarket intake, and get the fuel pump and FPR, what would be a good upgrade size for the injectors that would give me an increase in power with out running the risk of being too rich?
Bogging, rough idle, low MPG, failing catalytic converters, backfiring. Also, your oil will be ruined in short order.Chaotic_Warlord wrote:- Is there a such thing as running too rich, if so what are the effects and symptoms of it? I know that too lean leads to detonation and engine failure, that's about the extent of my air/fuel ratio knowledge.
I don't believe so.Chaotic_Warlord wrote:- Is there a formula to calculate how much power can be made from adjusting your Air/Fuel ratio?
Anything that can manage the fuel injection system accurately will be fine.Chaotic_Warlord wrote:- If I were to get OEM SR injectors, the 255lph fuel pump and an adjustable FPR would I need to get a piggyback AFR computer (like the Apexi Neo) or would I need to get a tuned ECO in order to make power?
With the mods you listed the injectors would never approach their flow limits.Chaotic_Warlord wrote:What would happen if I were to upgrade to a 555 SR injector?
If you're tuned right, you should never run rich.If you don't get a tune for your change in injector size, your car will never run right.Chaotic_Warlord wrote:Thanks Razi, but if I get an aftermarket 255lph an adjustable FPR, and run the 370cc injectors, but stayed with the OEM air flow system (intake, intake manifold) would this make me run to rich or no, and if I upgraded my entire fuel system and switched to an aftermarket intake, what kind of power gains can I expect?
Will doing this bring me closer to the 190hp mark or no, given age and the mods I have already I'm guessing I'm close to the 175hp range, but since I have only the butt dyno as a judge I have no idea, it sure feels a lot quicker than when I first got the car.
No, it is all in how you tune everything.Chaotic_Warlord wrote:Thanks Razi, but if I get an aftermarket 255lph an adjustable FPR, and run the 370cc injectors, but stayed with the OEM air flow system (intake, intake manifold) would this make me run to rich or no, and if I upgraded my entire fuel system and switched to an aftermarket intake, what kind of power gains can I expect?
Actually, 12-13.5:1 is richer then 14.7:1. 14.7:1 is the stoichiometric ideal (read: chemically balanced) mixture, but people generally run a tad richer to stay on the safe side. You do not want to be running lean at WOT.Chaotic_Warlord wrote:So I found a couple similar discussions on other car forums, it would appear that this is a much debated discussion. While the perfect A/F ratio is supposed to 14.7:1 but it would appear that 12-13.5:1 is the more ideal A/F ratio which would lend to a leaner condition. But at the same time a richer mixture would seem to not only keep the engine cooler but also lend to more power at WOT.
I think that's actually what your stock ECU does.Chaotic_Warlord wrote:So is there a way to run leaner at part throttle and then change over to a richer mixture higher up the powerband towards WOT?
So a FMU system would allow me to tune my AFR's to how I want them to be all throughout the power band, correct? Or would i need to get a Piggyback system like the Greddy E-Manage in order to tune to that level of detail?car nut wrote:I think that's actually what your stock ECU does.
The FMU will only allow you to control the the fuel system.Chaotic_Warlord wrote:
^ thisPoorManQ45 wrote:
You also need to control the ignition system. Specifically spark advance/retard at different RPMs
The voltage output of the o2 sensor determines if you run lean or rich and that constantly changes.and thats about all i have to add to this convo sorry guyscar nut wrote:
or get a big carb and advance it 16 degressRazi wrote: you should retard your timing via your distributor by about 2 degrees to keep your engine from exploding.
PEZi720 wrote:or get a big carb and advance it 16 degress
An injector is simply a solenoid that opens for a specified duration to allow fuel to flow.Chaotic_Warlord wrote:Interesting, thanks for the input.
Can someone explain what an injector duty cycle is and why you some injectors need resistor packs. Do injectors have a set amount of electrical current before they are maxed out? Is that what the resistor packs are for? If this is case what is the normal amount of flow of the stock KA injectors?
To a certain point this is true. But usually if you go more then 1 point in either direction you're approaching the limit of what the system can compensate for.Klits562 wrote:The voltage output of the o2 sensor determines if you run lean or rich and that constantly changes.and thats about all i have to add to this convo sorry guys
Rare_f8 wrote:To calculate theoretical hp:
You need to assume a few things:
A/F Ratio = 11 to 16 (for best power 12 to 13)
BSFC (Brake Specific Fuel Consumption)- .5 modern stock engine or turbo charged intercooled engine, .47 Hi-Perform engine, .42 Race Engine, .55 Supercharged/Turbo Charged non intercooled engine
VE (volume efficiency) - any where between .8 to .95
Now you can calculate the following:
Displacement (DISP) = (1/1.27)(#cylinders)(stroke)(bore)^2 (note bore and stroke are in inches)
Volume Flow Rate (VFR) = (1/3456)(DISP)(RPM)(VE)
Mass Flow Rate (MFR) = (1/(T+460))(2.703)(P)(VFR) T, P are outside temperature and pressure. (Note this is MFR isn't accurate for boosted applications, I have another method actually...)
HP=(1/A/F)(1/BSFC)(MFR)(60)
Also a general tip.. if you are using around 12 a/f and .5 bsfc... a rough estimate of power is 9.5 to 10 HP times MFR...
Modified by Rare_f8 at 1:10 AM 4/9/2010
As long as you can hook everything up to the computer so you can chart everything out over the RPM range it doesnt matter what sensor you get.Chaotic_Warlord wrote:As far as the Wideband o2 sensor goes, I really want to pick one of these up, but it would seem that the Innovate systems seems to be the best one out there but it's sooo freakin expensive. Can I just get a Bosch 5 wire wideband, and a AFR gauge and just use that to tune without having to get the whole Innovate system? Or are there other offerings out there that do the same job as the Innovate System for a cheaper price?
Those two mods should decrease restrictions in the intake.Chaotic_Warlord wrote:I don't have an aftermarket intake, so I want to get one of those, but I also want to pick up an aftermarket Intake manifold, with these 2 mods does your air/fuel ratio change since you are supposedly bringing in more airflow or is this a myth?
IIRC, isnt the Q45 TB a 90mm? That's overkill. LOL. But anyways, to answer your question, the ECU will have no idea what's going on as the TPS sensor voltage is much different. Now, a piggy back unit will be able to be set for a wide range of inputs. Or, better yet, a full control unit would give you infinite adjustability. You'll be able to program the unit to accept whatever input signals that you want, even add sensors and dohickeys if you would like.Chaotic_Warlord wrote:Also if you change to say a Q45 throttle body, can you still run on the stock ECU or does the ECU freak out and not know how to handle it?
Not really. Just sit down and plug in the numbers...Chaotic_Warlord wrote:
That's a ton of math, I'm confused just looking at that.
in that case, your entire post is useless for some time lol.DevilMB3017 wrote:tl;dr thread.
