Air/Fuel problem
mistamacadamian
Car: s13
My s13 is running very lean, 16-18 all through rpms. ITS NA, Im running it off a auto ECU and it is a 5speed, nismo exhuast no cats, apexi safc, eugo wide band, and short ram intake. Im wondering if anyone has had this problem and what to do? I have a manual ecu but my car was running like **** when i first swapped it to manual and the rpm gauge didnt work with the manual ecu in, so i left the auto one in. i will switch it again tomorrow to look for a difference, any help?
Ligouri Rd
Car: '96 Nissan 240SX
Bad o2 sensor mabye driving the ecu to run the engine lean. What are your in/out settings on the SAFC, are you running any correction?
neverlift
what are your afc settings? make sure you dont have them negative..... most stock ka run RICH. Have you checked the ecu for codes?
mistamacadamian
Car: s13
only correction is on low throttle 1000rpms is at -6 just for idle. could it really be the auto ecu?? i dk what the diff is between the 2 ecu's, and no codes show up or anything. ill be plugging the manual ecu in today, only problem is i wasnt getting rpms, it wouldnt work. ill let you guys know thanks
