air/fuel oil pressure gauge install HELP!!!!
maka
Car: Kouki S14
hope this is the right forum. anyways, i tried searching and all i could find was sr20 install on the air/fuel gauge, dont know if its the same.
is there a diy forum on doing the ka24de gauges or anything.. thanks.
480sx
Car: 1996 Pearl White 240sx
For starters, unless its a wideband o2 gage its useless. I mean yea the narrowband o2 gages look pretty, always flashing around and actin a fool but, completely useless. I think you have to tap your front O2 sensor for this, but i would just sell it.
Im assuming you got an electric oil pressure gage? If so, it came with a sending unit. This is typically a goldish colored cylinder thing. What you need to do is take either take out your stock oil pressure gage sending unit, which is down next to the oil filter. Its a small, usually blackend from oil leaks, cylinder. You really dont need it, but some cars will throw a code if its not installed. If you want to keep it you need to get a fitting that screws into it and has 2 ports. I would recommend against using an oil T, those are prone to break.
If you wana junk it, just take it out and install your stock one. Be really careful, because those threads are super easy to crossthread. Teflon it up before you put in in. Honestly its a real big pain in the a$$ to get to. I just installed mine, but i had the intake manifold off.... I think your best bet is to try to get at it from the underside of the car. You might have to take off a bracket that attaches from your intake manifold to your block. It will be right behind your alternator.
Hope this helps man, and good luck.
maka
Car: Kouki S14
thanks for the info. so i was wondering. what main gauges would you think that i need when i go boosted....?? boost, oil, ???? i would like to have a set up of three gauges. thanks...
jaytv1019
Car: 1995 240sx w/redtop swap
boost, oil pressure, wideband O2, and EGT.
Your oem water temp gauge is as accurate as any other gauge so I never put one in. If you get a nice wideband/data loger (PLX) they usually have a built in EGT (exhaust gas temp) gauge. That's my vote!
maka
Car: Kouki S14
a little new to the gauges scene, and just wondering what is wideband/data logger (PLX), and the purpose of knowing what the temp of your exhaust??? dont really see the point in knowing your egt?? tuning?
180fan
Car: 89 fastback
richer tends to lower the temps, leaner tends to run hotter. the temp of the exhaust gas can tell you if you're lean or rich basically.
maka
Car: Kouki S14
180fan wrote:richer tends to lower the temps, leaner tends to run hotter. the temp of the exhaust gas can tell you if you're lean or rich basically.
ahhhh.. thanks for the info. guess i am getting an egt gauge and ditching the air/fuel gauge
