Unfortunately the tool that you mentioned does not fit. There is a metal shield around the sensor that doesn't allow the tool to squeeze into the tight space to grab onto the sensor. The silver socket in the autozone kit below (see link) fits. Unfortunately, it sticks out too far and doesn't allow for as much leverage as the other two sockets in the kit (if they were to fit on my application).
Other things I tried today:
I removed the cowl which gave me a few extra millimeters of space, but it wasn't enough to get the leverage with a breaker bar.
I clipped the wires off the sensor and torched as much of the area directly around the sensor without frying any of the other components in the vicinity.
I tried several more times pulling and yanking on a ratchet with no luck.
BTW I sprayed PB blaster on it several times over the past 48 hours.
Any other ideas? Are there any special curved breaker bars out there to give additional leverage in awkward spaces?
http://www.autozone.com/autozone/access ... 72729_0_0_
