Air/fuel gauge question
CaEric
Car: 91 Sr Pwred Coupe
So there three wires .red/black/purple/i have tit hooked up to pin 29 which is the o2 sencer wire ..but iam not getting a reading ...any thoughts as to what could be wroung ?
float_6969
It's because you hooked tit upto it instead of the purple wire.
JK
Try running a wire over to the plug for the O2 sensor and tapping in there. You could have a bad O2 sensor.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Just an FYI, all that gauge is going to do is bounce back and forth while you're driving and read full rich at WOT.
boost_boy
c-rad wrote:Just an FYI, all that gauge is going to do is bounce back and forth while you're driving and read full rich at WOT.
In better terms, it' s near worthless. However, it does signal to you when your oxygen sensor has shat itself .
Dee
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
wide band or nothing.
c-rad
yourmomsrps13 wrote:wide band or nothing.
yourmomsrps13
damn c-rad you need a new steering wheel, drive much? lol
c-rad
yourmomsrps13 wrote:damn c-rad you need a new steering wheel, drive much? lol
Florida sun = teh suck. Plus, its almost impossible to find a hicas steering wheel
float_6969
It's like trying to find a HICAS steering rack. I can't get my hands on one to save my life.
yourmomsrps13
why is a hicas steering rack better? and i have a steering wheel in mint condition but not hicas
rchboy
i believe a hicas steering rack has a better range of steering angle, wheels will turn more, at least im pretty sure.
c-rad
yourmomsrps13 wrote:why is a hicas steering rack better?
15:1 steering ratio as opposed to 17:1 on the non-HICAS rack.
yourmomsrps13
imagine that with the tein tie rod spacers
c-rad will that steering wheel help you out at all?
Modified by yourmomsrps13 at 9:14 PM 8/13/2006
c-rad
yourmomsrps13 wrote:imagine that with the tein tie rod spacers
Negative. The HICAS steering wheels have a sensor and gear that determines the angle of the steering wheel. Apparently the TT 300ZX aftermarket hub works, so I may go that route. Unless I can find one of those nifty JDM wheels that say "hicas II" on them
