Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Sep 17, 2003 3:28 am
Nissan selects the MAF diameter so that under max flow [max rpm] the differential pressure across the unit won't exceed 0.25 psi [roughly 7" of water column].
This max restriction represents at absolute most 1.5%. In other words a 300HP engine might produce 4.5 HP more without the MAF ............just a straight tube of equal diameter and no air straightening/trash screen.
Unfortunately the ECU needs the CORRECT signal from the MAF to operate.
All Nissn MAF generate the same 1-4.8 volt signal just correlating to different air flow mass amounts. The inside diameter is the clue as to what you have. The Q MAF is a 255 grams per second type good [amount of air mass] for 330 HP......before the voltage maximizes. The air flow can be higher just that the ecu doesn't know it's higher.
