USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Sat Aug 23, 2003 12:57 pm
I think it is too, it reads about a hair under 0 when I turn it off.
But have (according to the gauge) 18 inHG at idle, and 24 inHG when cruising with no throttle.
If I am just driving it, like back and forth to work, the most boost I will see is like 6 pounds and that is if I am going up a hill. But if I romp on it.... 10 pounds.... fuel cut.
So... I dunno. I'll have to have you drive it Jon and let me know what you think, kinda goofy.
Oh well.... sooooo many little problems to fix, so little time.
Oh yeah.... the whole right side of my cluster decided it doesn't want to work anymore. Odometer is stuck at 138824 and tripmeter is stuck at 000.0. And the HUD comes on when it wants too, and it no longer reads the speed I am going, I can be cruising to work and it will just blink 0 mph at me every now and then. So...... anyone have a 91-94 analog cluster or JDM cluster they want to get rid of? I will also need the subharness too since my shizzle is for the digital cluster.
Then I have to find out why the car runs like complete crap when I first start it up in the morning. It wants to idle at like 400 rpms and is real boggy and misses like a biatch. But once it is warmed up, it runs great. Hot starts aren't a problem, just cold starts. Could be a possible leak into the Air Regulator, but I haven't had a free second to check it out.
Here's the fix-it list-----------------------1. Unghetto fab my Intercooler2. Find a new cluster3. Find out why I hit fuel cut WAY too early4. Cold starting problems
I know its not the timing either. I set it to 17 degrees and it holds it now.
Joe
