Air flow meter in the intercooler piping? Good idea?
Dan1200sss
Hey guys, I'm struggling for room in the dattos engine bay to fit the z32 maf infront of the turbo with a decent amount of space between to prevent any afm issues that could occur. So should I put the afm in the intercooler piping after the turbo ? What are the pros and cons ? Cheers :)
dash
Car: s13 ca18
u couldn't mount the afm with filter under the panel, ahead of the tire in the wheelwell (behind the splashguard of course) ?
Some sucessfully 'blowthru' z32 afm mounted in the cold pipe, a little bit before the throttle body. All had some tuning means tho iirc.
Hypergear powerful CA18 on ns.com blew the plastic body apart ~24psi. Mounting the actual sensor element onto a metal pipe would solve that I'd think.
Have u check the many datto installs ?
http://datsun1200.com/modules/news/ gallery for example
float_6969
As Dash said, You can do it, but you need to be able to adjust the tune as I don't know if it will work the same. I would place it after the intercooler, with as much straight pipe before and after the MAFS as possible. The plastic housing doesn't seem to take a lot of boost either.
