Air Filter Removal
Deke40
Car: 07 Nissan Versa SL HB 08
I was out early this morning and checking everything under the hood of my V and wiping down the accumlated dust and grime. Compared to my CRV I couldn't believe how easy changing out the Air Filter will be. Just two compression clips, pop the cover, and there it is.
Just be sure and get the cover back on the right way. The two extensions on the inside of the cover go to the bottom to keep a tight fit on the filter and keep the dust and debris(I vacuumed the box out while I had the cover off) on the inlet side.
