smockers83 wrote:Reverse engineering not only consists of figuring out how someone already did it, but also how to make it better. Why should you be the only one allowed to do such things?
I question how it could be better than just fixing factory grounds or replacing with engineered ones.
That said every grounding kit (except for maybe one or two I have come across) are simply a bunch of cables attached to points without concern for the possible issues of circular currents, etc. The couple I have seen do things like grounding blocks to avoid stacked grounds, grounding rings for the same reasons. Others follow the factory ground path which is often done in other industries. By this I mean that if a chassis ground could be compromised by where the various chassis parts meet, then a ground is provided across the junction point to guarantee the chassis ground. Some simply jumper the junction, others follow the factory path with a single unbroken conductor threaded through grounding blocks attached to each side of the chassis junctions.
These kits to me have been engineered, probably not needed in most cases, but at least don't look like possible trouble especially later on where age attacks things like the stacks present on most.
Perry
