Air Filter Choices
CA18Fastback
Hey guys, i'm looking to buy an APEXi, HKS, or Blitz air filter to open things up for my project. What i'm wondering is which filters will fit the CA Maf? Will ones for the SR work? I'm hesitant to buy an SR one because i dont know about the sizing.
Thanks!~Ian
themadscientist
the filters come with adaptors for the AFM, the SR and CA AFM mounting patterns are NOT the same, buy one for the CA.
CA18Fastback
where? i've looked online at phase2, and enjuku but i cant find a filter w/ a CA fitting. Should I just upgrade to Z32 for my power goals anyway?
~Ian
themadscientist
what are your goals?
Nathan
speaking of z32 maf...does it work with an Apexi Power FC? I thought it would but someone had a problem over in the SR forum.
NeedCAforS13
Car: CA swapped S13 coupe
TMS...would a ca18de after market fitting work??? For example, could I go get a K&N pulsar cone and bolt it to the ca18det mafs you're sending me :D (get my money yet..should be there soon if not!)
Sean
CA18Fastback
my goal is between 275-325whp so i think i'll need the z32 maf. is that correct?
~Ian
chezina
@ NeedCAforS13 : Should fit, cause the MAF is the same on CA18DE and DET. The fitting is the same the only thing that differs is that the K&N filter from the DE is a bit shorter (atleast in the K&N kits available here).
themadscientist
NeedCAforS13 wrote:TMS...would a ca18de after market fitting work??? For example, could I go get a K&N pulsar cone and bolt it to the ca18det mafs you're sending me :D (get my money yet..should be there soon if not!)
Sean
Stop! don't buy the K&N, the AFM on the harness I am sending you already has an HKS adapter on it.:) whaen you get it just score the proper HKS filter cage for the adapter.
NeedCAforS13
YOU ROCK!!!!! :D thanks man...is that proper hks filter the green mushroom one? or how do i tell???
Sean
themadscientist
it's just the adaptor to mount the "bug eye", you have to buy the actual filter cage and foam but the adaptor is still on the flow meter.
Xero
about the Z32 MAP and the Apex'i Power FC, that guy needs to go read the Apex'i website, that problem has already been identified and corrected,
BTW, is the GTR MAP the same size as the Z32 MAP? just lookin' =)
hey themadscientist, do you have any sort of IM'ing software like AIM, or ICQ? I wanna talk to you, my Email is [email protected] THANKS!!!!!
themadscientist
if you mean the MAF, no the GTR has two small ones vice the Z's one large one. I have seen GTRs with double Z AFMs
Xero
wow, cool...
Spectre_240sx
Car: 1990 240sx SE
Hey, I was just checking the application chart on Apexi's site and I don't see anything about CA equipped S13's. Is there a PowerFC that will work with the CA18DET?
themadscientist
you can only get the CA18 Power FC from a Power Excel dealer, it's special for some reason.
Xero
is that from a Japanese Power Excel dealer, or any Power Excel dealer?
doesn't matter to me, I'll get it :D :D just for other peeps who aren't going abroad,
CA18Fastback
do i need the Z32 MAF for 275-325whp? No one ever responded so I thought I'd ask again.
~Ian
Nathan
Maybe you should start a new thread...I'm curious too :)
themadscientist
Xero wrote:is that from a Japanese Power Excel dealer, or any Power Excel dealer?
a liscenced Apex dealer shop should be able to order it for you. I have been told second hand that out of the box the "power excel dealer" Power FCs require some further setup once installed on the car.
themadscientist
CA18Fastback wrote:do i need the Z32 MAF for 275-325whp? No one ever responded so I thought I'd ask again.
~Ian
The CA AFM runs out I would speculate around 250hp, probably sooner. There are several ways to monitor the voltage out of the AFM to see when it maxes out, the Apex SAFC has that function or just a basic mulitimeter will work. The 300ZX or Infiniti Q45 are the best upgrades. They have more potential to measure the air but need to be tuned for. If you just slap it on and go you will have trouble.
