Versalino »
https://forums.nicoclub.com/versalino-u159325.html
Wed May 05, 2010 8:41 am
Update!
So, I've got my deflector and already installed it last night.
Oakville Nissan in Canada (where I got it from) was very courteous, shippment was on time but a bit pricey.
Installation is straightforward but slightly more complicated than on other brands. All you need is a screw driver and a rubber hammer in case the push pins arent align perfecty. In that case you might need to hammer them in from the inside of the hood and a rubber hammer goes a long way without damaging the metal or the paint. (and the pins are under the hood anyways, so no biggie)
After installing I noticed that mine was off center by 1/8 of an inch, but you can notice by close inspection only, so its ok with me.
My only issue is with the "bumpons" - the little rubber half globes that are sticking on the hood freventing the deflector from touching the hood. The two on the side are perfect, but the one on the middle has a 1/8-1/16 of an inch gap between the top of the bumpon and the deflector. It still doing it's job, since the deflector does not touch the hood, but I would feel better if the two would connect. I was thinking about moving it further down the hood, but there would be no guarantee that it would make any difference and it would have required me to take the whole thing apart again, so I will leave it for now.
Anyone else has had this issue?
And finally, where could I get more of those bumpons in case I'd like to put 2 more evenly spaced?
