I just found this article.
What is a Front Air Deflector and where is it Located?
A front air deflector, also commonly referred to as an air dam or lower valance, is a plastic or metal panel located at the front of your vehicle, under the bumper. In many cases, the part is just a cosmetic piece of the vehicle, with no function other than appearance and to conceal what is behind it; some also come with provisions for things like fog lights. However, this is not always the case; there are some applications where the deflector helps to control the flow of air around your vehicle, channeling air around the bottom of the engine compartment. This makes the front of the car more aerodynamic, and adds downward force that keeps your tires firmly attached to the ground at highway speeds, equaling more grip and better control/stability for your car or truck. The air dam also channels air into the engine compartment to aid in the radiator’s cooling process.
The term “air deflector” is also commonly applied to other types of deflectors as well, such as those found on side and rear windows, sunroofs, and even trunk lids, which function a bit differently than an air dam. Some vehicles also come with an air deflector mounted on the hood. This piece, which is made of plastic, is sometimes called a wind deflector or a bug deflector because it controls airflow to keep bugs, rocks, and other pieces of road debris from hitting the hood and windshield. Wind deflector is also a general term commonly applied to these other types of deflectors as well.
I just wonder if its cause tic or otherwise for our car. It seems way too thin to be of any significance for our cars.
