loystock »
https://forums.nicoclub.com/loystock-u10145.html
Tue Jul 20, 2010 12:12 am
Welcome to NICO.
Yes, your evaporator drain line is clogged. But I don't know which car and model year you have. In general, the drain line goes thru an orange tube close to the firewall and wheel well. So jack up the front pax side of the car, install jack stands, and then look for that tube. You can use a wire (or coat hanger) or compressed air to unclog the line. If unsuccessful, you may have a lot of debris inside the evaporator/blower box. You may have to remove the glove box to access the drain hole.
