RunCool »
https://forums.nicoclub.com/runcool-u60958.html
Mon Jul 09, 2007 4:42 pm
If you guys are doing any work on your A/C system your best bet is to convert it over to R-134. Its very easy to do. First off your going to need your old R12 vacuumed out. Once that it is done, it is recommended to change the receiver dryer, because it has the old R12 oil in it, which should not be mixed with the new pag oil but you can mix it and it won't harm your system really. Then remove the stems from the old R12 high and low side. Install R134 fitting, and charge it from the low side with the AC on high. Buy a can that has the pag oil mixed in it, use about 6 ounces. Start with two cans of R134 (1can of stop lead won't hurt), and check the low side pressure with one of the gauges you get when you buy the can. Its not the most accurate thing but it works. Should be around 28 if i remember.
