qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Wed Mar 26, 2008 6:02 pm
I understand your point and where you are going with this but...
There is nothing half-*** about troubleshooting the system without wasting the whole freon charge and spending hundreds of dollars for someone to do it only to later find out it was a fuse or defective switch. There are many areas of the a/c system that can cause problems that have nothing to do with the freon level or a leak. So you are saying that the first thing you personally do every time you have an a/c issue is run down to your local Q45 mechanic and have him check for leaks and suck out all the freon, vac, and refill it? That's rediculous, honestly. There are many electronics, relays, fuses, controls, etc. that could just as easily be the issue.
I guess everyone has their own beliefs of how things should be done. There is no harm in checking pressures on the system and they will tell you a lot. If a mechanic were to dive in and evac and recharge an a/c system without at least checking things out first it would be my opinion that they have no idea how to properly diagnose an a/c system and they would never work on my car. There are far too many mechanics these days that don't know how to troubleshoot at all.
