nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Fri Oct 24, 2008 1:11 pm
I think as long as you have a condenser, a blower, a compressor and your high and low pressure lines you should be able to get the AC going fine. The electronics will be a little different, but it should only be making sure the compresser switch is wired to the car properly. The blower should function aside from the actual AC unit. Maybe someone else can weigh in on this. Also, there have been a couple of people that have made brackets where you can use the KA compressor on your SR swap. So try to use everything that is already made for that car and you should have no problems.
BTW, I dont think the heater core does anything with the actual AC setup. The heater uses water from your engine while the ac uses freon and a change in pressure to get a lower temperature and then it blows that chilled air through out the car. at least that's how I understand it.
