sleepyRPS13 »
https://forums.nicoclub.com/sleepyrps13-u4928.html
Mon Apr 17, 2006 11:03 pm
the cold and hot lever temperature control(aka blend door) is the only mechanical component so its the last thing that can break.
everything else runs on a motor on a linkage (there is only 2 of them: air recirculation & main vents controls.) make sure your getting power to the (((push control unit))) & proper ground & good fuses. try pushing the the vent push buttons while watching the motor move, if it doesnt, check for 12v at the motor.
if the blower is not working : fan switch, relay/fuse , resistor, blower motor.
wish i could help more but i gotta study.
definetly take it to a/c shop have them clean and remove air/moisture the refrigerant. check the levels of the freon & oil, if its low, it probably means theres a leak. they have a freon leak detector or special die they mix with the freon makes it easier to spot leaks. a common place it leaks is by the seals on the compressor which dries up if you dont use your a/c. if you dont care, just top it off. but if you got r12a its going to be expensive. better get a r134 retrofit. remember not to mix (freon & oil) and get it poperly retrofitted.
