1996QShip »
https://forums.nicoclub.com/1996qship-u182376.html
Mon May 09, 2011 8:48 am
Okay Guys, here we go:
I have a 1996 G50 with is only blowing ambient air. I've checked the fuse in the panel with is good. It also blows at the correct speed depending on the setting. It switches the modes properly too. I then did the self diagnoses as directed by the FSM and received error codes: 21 with flashing, 41, and 51.
The question I have is what do you think could be the one problem resulting in the various error codes? I can't see more than one thing going wrong at the same time. looking at the FSM I almost have to think my air mix door motor is bad but I just don't know. Your help and input would be much appreciated as I'm dying of heat here in Louisiana already.
I look forward to your responses
