Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Thu Aug 23, 2007 4:19 am
Well, a household air conditioner draws far more power than an automotive one, since it has to cool a considerably larger area. So obviously a household one would not work.
But IIRC, the Prius has an electric A/C system, and it can function when the gas motor is off as a result.
In the sense of a normal gas engine, you would just need to use the appropriate sized alternator. Granted, the new alternator would itself cause more drain. The question then becomes, however, does it generate MORE drain than the A/C system would, or less?
