air conditioner problem
General discussion area for the L32-chassis Altima
whitworth001
Car: 2007 nissan altima 3.25
My air conditioner smells like anti-freeze. The dealer says it is "bacteria" from condensation not draining well. They sprayed a disinfectant spray on it to stop the smell but that is a band-aid. I think they should just replace the air conditioner.Anyone else having this problem.?
Rolling Estonian
Car: 2008 Altima Coupe 2.5
usually the "bacteria" smell goes away after a couple minutes. does yours?
Does it smell sweet?
marlin29311
Car: 2008 Infiniti G35x
Replacing the air conditioner will do nothing. You will still have the same issue - its just the nature of the beast in most cases. A lot of people suffer from this actually...not just Nissan.
whitworth001
It only seems to get worse as the air is on longer. I even smell it when the heater is on. The Nissan repair guy took out my dash and said it is sealed, no leaks and the condensation is draining well. He also had two other cars come in with a bad smell, but they said theirs smells like "dog pee."
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
A musty smell is typical but should dissapate after a while, i'd definiely replace your in-cabin microfilters they trap all sort of nasty stuff and it builds up. My Titan also got the smell after a while, hasn;t happend yet on the altima, but i suspect it will
Return to “4th Generation Altima Sedan (2007-2012)”
