Thanks BrianGuess I'll have to try to fix the illumination display first before I can carry out the self diagostic program. A member posted a repair on the circuit (Pic). Would you happen to know if that was successful? Dumb ? I know but thought someone just might know.maxnix wrote:That "process" to which you are referring is to place the HVAC into diagnostic mode.
Thanks HeathI'll check all your suggestion out during the week. I'd hate to think it the controller stuffing up as this has extra buttons for the controller in the arm rest in the back seat and "Air Purerfier" in the parcel shelf.In the pic there are 3 buttons down the right side of the controller.Q451990 wrote:It sounds like you may be low on refrigerant... it will tend to cause the system to freeze up and stop working - but it's a gradual thing, and will still cool some. Is your problem like flipping a switch (or pressing the ECON button)? Keep in mind that there are (at least) three overides that can tell the ECU to turn the compressor off.
1) The dual pressure switch (located on the drier) can open the circut due to high pressure. Same dual pressure switch can open due to low pressure.
2) Sensor on evaporator coils can tell the unit to open if the coils are freezing.
3) Sensor on compressor can open the circuit due to overheating.
When you have the problem, is the compressor engaged? If not your controller may be crapping out... Mine actually failed in an unusual way that caused the compressor to not run when the display was out. Jerry Tucker said that this was unusual.
Heath
It's with a circuit board guru now. He's resoldering sus connections and replacing 7 caps.. He's also replacing bulbs with LED's and resistors. Hopefully after all this I'll be able to get a readout on the display screen and get a code to indicate the reason the A/C starts blowing hot air.maxnix wrote:That's an option we didn't get, and obvoiously requires more refrigerant and more controls.
Take it to an HVAC professional, not your local garage.
Happy to report a MAJOR win! A/C display is finally ILLUMINATED. The circuit board guru found several "Dry Joints" also 3 of the 7 Capasitors were "wavey" so he replaced them (7) all. While he had the board I got him to replace all the back lights with blue LED's. He roughed up the tops so they wouldn't concentrate light in one spot and put mini resistors on each of them to give them the equivelant of 12 V's. The other win is that it has stopprd blowing hot air, I guess somthing on the board was giving a bad signal (maybe one of the caps.) or maybe it just needed some TLC.Parts $20AUSLabour $150AUSmaxnix wrote:Cool. Keep us updated.
Thanks Wes,Been trying to post a pic of the Caps that were replaced but I keep getting a bad post message. What am I doing wrong?elwesso wrote:Greg, i'll post in your other thread.
EDIT: I deleted your (accidental) double post.
Thanks again Wes, I seem to have stuffed this post up. I be pleased if you could sort it out for me. There are plenty more pic' if you would like them.Cheers Gregelwesso wrote:Greg, i'll post in your other thread.
Must have been holding my tounge wrong!elwesso wrote:is the picture too big? Cant be more than 500k
