wasnt to sure where to put this...let me know if anywhere else would be better, but im looking into getting a air tool set-up for when i start to do more work on my 240. I cant figure out which size air compressor to buy, like what size gallon, and what horsepower to get. I'm looking at getting this impact wrench
http://www.toolbarn.com/product/portercable/PT501/ or this one from home depot (link isnt working so here is the info on it.....
HUSKY1/2 In. Impact WrenchModel H4140
At 5 1/2 lbs., this Husky air tool deliver the highest horsepower in its class. With 500 ft. lbs. of maximum torque, it has been engineered and designed for the most demanding of fastening applications. You'll find the built-in regulator a convenient tool for adjusting your power requirements. The through-handle exhaust and patented muffler helps to reduce noise level while the internal components are protected by a steel housing. This tool offers 1,300 Impacts per minute and 8,000 RPM (free speed) no load. The Home Depot warrents this Husky Air Powered tool to the original user to be free from defects in material and workmanship.
• Provides up to 500 ft. lbs. of maximum torque.• 1300 IPM• Selectable power output control• Avg 3.5 CFM at 90 PSI• Oil bath clutch lubrication• Highest Horsepower in its class• Hardened Steel Anvil Bushings• Patented Muffler
Internet/Catalog # 165631Store SKU# 666531 Price: $99.97/ea)
i'll be using these tools for pulling the engine and swapping transmission's so please let me know if these tools will do the job just fine, and hopefully i can get help on which compressor to buy. (trying budget this also)
