Air Charge Sensor?
super-KA
Car: 1990 240sx
I have a '90 240sx with a KA24E and I have a cone filter I was wanting to use on it. I noticed the stock air box has an air charge sensor, and I was wandering if I replaced the box with the filter, what would I have to do with the sensor? Could I leave it off, or will I have to tap it into the intake pipe? Thanks for the help.
theother1wstolen
Car: 92 240sx Coupe SE
are you talking about the maf?
super-KA
Car: 1990 240sx
No, not the mass air sensor. There is a sensor tht plugs into the actual air box that contains the stock air filter. The box is being removed for a cone filter. I wanna know if I can lose the sensor alll together, or will I need to plug it into the intake pipe somewhere?
super-KA
Car: 1990 240sx
I know lots of people on here have cone filters, so what did you do with the air charge sensor on the air box?
theother1wstolen
last i checked there was no sensor inside the air box, a picture perhaps?
super-KA
Car: 1990 240sx
It's strange nobody has seen this. I will get a pic of it tomorrow and post it for sure. It is on a single cam KA. I work at an auto parts store and our computer even lists it as having an "air charge sensor" and I have identified it with a picture that this is what that sensor is. I'm assuming it tells the computer the temperature of incoming air. Will get a pic up tomorrow though.
super-KA
Car: 1990 240sx
Here is an inside/outside view. It just plugs into the air box right near the MAF. Can it be done away with, or will taking it off mess up the ECU's functioning?
brandonDavid
Car: 1992 240sx, 1992 D21
don't take my word for it, but it should run fine. buddy has a 4 banger stang had the same thing, funny thing is, it's the same maf and the regular ka. but that's been out for a while and he's never thrown a cel
super-KA
Car: 1990 240sx
I think it should be fine without it as well. I doubt a '90 computer is sophisticated enough to make big changes according to air temp, but again, not completely sure. Anyone else?
super-KA
Car: 1990 240sx
If nobody else has anything, guess I'll just give it a shot. I was just trying to figure it out now while the motor is apart so I could get rid of as many wires as possible.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Incoming air temperature sensor. Just shove it inside the cone. The screen in front of the mafs will stop it from getting sucked in.
super-KA
Car: 1990 240sx
98s14inaz wrote:Incoming air temperature sensor. Just shove it inside the cone. The screen in front of the mafs will stop it from getting sucked in.
Um....haha. Has anyone ran without it?
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
My 93 didn't have it.. The 91 does, it's unplugged and no problems..
