qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Wed Feb 06, 2008 9:12 am
You are absolutely right Jack. One of the bits of data we indent to check is the power used by my air compressor during fill up. Something in actual production and daily use like that production aircar, really needs to address that issue. From a cost standpoint for the end user, the electricity used to fill the vehicle is much less then the gasoline would cost to drive that distance. That, of course, doesn't address the issue of the pollution made to produce that energy.
Actually tho, if you really broke it down I believe that gasoline would still be much worse than an air or electric vehicle. In a gasoline vehicle there is energy and pollution made/caused to make the fuel and also pollution caused using it. In an electric or air vehicle the only pollution produced is from generating the electricity and no pollution produced in using that power. I'm not sure how the production of gasoline compares to generating electricity. There sure is a lot to consider when you are trying to determine how "green" or efficient something is.
Another advantage to air or electric vehicles is that, like you mentioned, you can use renewable sources to produce it like wind, solar, etc.
Hopefully, getting the kids to start working on this stuff now they will come up with some great solutions for the future!
