Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Dec 21, 2002 5:31 pm
The entire air box system is tuned to minimize noise while not overly restricting air flow. At the same time creating WATER traps and drains to avoid hydrolocks.
From the front of the MAF [top of filter box after the filter] the worst total restriction to the atmosphere is 7.5" of water [roughly 1/4 of a psi]..........the oem factory filter only has a 1.0" restriction.
A 274 cubic inch engine can only ingest so much and the valves and head design are the major restriction. The whole system is tuned to have a negligable restriction until just past 4,000 rpm [the torque peak rpm], where it begins to be measurable on very sensitive equipment [manometers].
1 psi [28" of water] is roughly 6.6% so the whole system in front of the MAF leaves up to [1/4 of a psi] 1.65% on the table at 6,500 rpm and less than 0.5% at 4,000 rpm.
No filter no nothing in front of MAF might yield 5.0 HP at best. A K&N or other cone has some restriction so maybe a peak improvement of 2.5-3.0HP [below the repeatable accuracy of a dyno to accurately measure]!
The problem is the factory system is already a cold air intake [getting air from a plastic cone in front of condenser/radiator in a high pressure area [which adds around 0.75-1.2" of pressure at 80 mph [120 mph adds 1.9-2.5"].
Replacement Cone filter suck in heated under hood air after passing thru radiator and AC system in summer even winter.Every 11F rise in injested air temperature lowers the air density by 1% which directly reduces the engine power by 1%.
Thus the power difference between 32F air and 120F [88F/11= 8%].....humidity and real barometer are also significant effects].....but the radiator raises temp by at least 30-40F and the AC add 20-30F so a inside cone loses from 3-7% depending on ambient not to mention the radiative heat from the engine effects on injested air.
Hopefully you see that the small gain in lower restriction is immediately conteracted by the temperature rise and the net is almost always a significant loss unless some way is found to place the cone where it is only exposed to cool air flow, which creates water problems.
Sure racers with big engines use K&N but not in the rain or standing water and the air flow is routed so that the heat does add to problems.
