Air bag sensor
Pearlmagic
Yesterday, I spent 8 hrs cleaning and detailing my 2000 max. I went as far as removing front seats and center console to clean the interior. Now my problem is this. When I put the seats back in and connected the power seats, heat and the srs side air bags, I ran into a problem. My airbag dash sensor keeps blinking. I disconnected the battery for 15 minutes and reconnected only to still hag the problem. Can anyone give me a heads up on what to do to fix the problem?
Chris
Pearlmagic
Wow am I to assume no one can offer a solution? Have I stumped people with this one?
Chris
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Have you taken the code to Autozone (or a similar place) to have them check for codes?
audtatious
Autozone probably won't be able to pull airbag codes, just like they can't pull ABS codes....
Some searching found this:
Note: Timing is KEY, use a stopwatch if you have to.
1) Turn IGNITION on (but don't start car) 2) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second. 3) Wait 4 seconds 4) Turn IGNITION on (but don't start car) 5) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second. 6) Wait 4 seconds 7) Turn IGNITION on (but don't start car) 8) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second. 9) Wait 4 seconds 10) Turn IGNITION on (but don't start car) 11) Wait 3 seconds 12) Turn IGNITION off 13) Wait 2 seconds 14) START Car15) Turn IGNITION off16) Wait 2 seconds17) START Car
AIRBAG warning lamp should blink for 7 seconds and then go out and never come back on. If it does, then you have a problem.
OR
-open drivers door-turn key to on-press and release door jam switch 7 times-turn ignition off for 30 sec-start engine.
OR
From Diagnosis Mode To User Mode
After a malfunction is repaired, switch the ignition "OFF" for at least one second, then back "ON". Diagnosis mode is returned to user mode.If switching Diagnosis mode to User mode is required while malfunction is being detected, by turning ignition switch as follows:1) Turn ignition switch "ON"2) After "AIR BAG" warning lamp lights for 7 seconds, turn ignition switch "OFF" within 1 second3) Wait 3 more seconds4) Repeat steps 1 to 3 twice (Perform 3 times in total).5) Turn ignition switch "ON"
Pearlmagic
Believe it or not it worked(the first remedy that is). I can't thank you guys enough. You diffenantly have a member for life.
Pearlmagic
