So......... $1350.00 and "HOPEFULLY" all is fixed!
ANY ADVICE???
Red air bag light flashing on and off with the B1054 code!
Hello,Promise Land wrote:the system being "opened" means that the airbag control unit has lost connection to a sensor or airbag itself.
Answer me these questions and you can probably fix the problem with some info:
1. What has changed?
2. Has anything been repaired or changed out?
They are probably going to find all the sensors and check they are plugged in correctly. That means the one behind your front bumper and then the ones on each side of the car.
