I thought this might be some good information for you all.
Got this info from the shop that works on my Q45.
I had the car in for some other work to be done and my airbag fault alert light has been flashing since I got the car late last year. He got the codes out of the air bag system and found 7 faults. He said in his experience this means the fault is in the main airbag control module. What they do to repair this is to make sure there is power going to the module and its got good ground. If that is good, they pull the module and send it here.:
http://www.myairbags.com/product/airbag-module-reset-3/
They usually come back working just fine. A lot cheaper than buying a replacement module.
Hope this helps save someone some money.
