Air Bag Lights Blink!!
GBSilviaS15
It's so annoying, I have a 95 240sx, and the air bag light keeps blinking... I disconnect the fuse and it stays constant, I connect the fuse it blinks. Any suggestions?
Thanks
NISTECH
you have an airbag code stored, Probably control unit. Did you have the battery go dead recently? This can cause the code because if the unit sees less then 9 volts when the key is on it thinks something is wrong with the control unit. If the battery going dead was the case you just need to have the code erased from past memory to diagnostic record memory, this will turn the light off.
GBSilviaS15
How do I do that?
NISTECH
Only way I know how is with the consult[factory scan tool] I think some aftermarket scanners have the abitly to do it not sure though, it would be a snap on scanner if so.
