Air bag Light Problem
ahmed_elshaer
Car: Infinity QX4 2001
after cleaning my Qx4 i found air bag alarm light flasing. i tried to reset it as in this topic:
air-bag-light-flasing-t248779.html
but after few minutes from reset,it flash again. is there any way to know where is the problem and reset it?
i've nissan infiniti QX4 2001
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Make sure you didn't unplug any wiring harnesses by accident while you were cleaning.
ahmed_elshaer
i don't know where to check. is there any guide to know where is exactly the problem?
Towncivilian
I know there are a few wiring harnesses underneath the driver's seat, but other than that I don't think anything else is easily accessible while just vacuuming or other simple cleaning.
ARKQX33V6
The door switches may be off set from you rubbing the door frame clean. Examine every door frame, grab the switch under the rubber and put into the central up position, then look at resetting the alarm and follow the instruction, as to your manual.
If a switch is unable to be closed/open by the door it will reset the alarm and flash the warning again
