Air Bag light is blinking
General discussion area for the L30-chassis Altima
NjKnight
Car: 1995 240SX
Hey guys i have an 2000 nissan altima GLE My air bag light is blinking and i know it is not an air bag problem it is sensor problem.
does any body know how do you reset Air Bag Light if yes can you please help me out
Thank you : Jeff
wheelsspin
Car: 2011 Infiniti G37 S
If you reset the light and don't have the fault repaired, it will most likely just come back on. If you so desire, take off the negative battery cable for about ten minutes, then see if it comes back. Otherwise, you are gong to have to go to a service center that has a scan tool that is SRS compatible, and have them reset the light. Although, they would probably only do it if the system had been repaired.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
If you have an airbag sensor problem, I would get that checked out. A lot of times problems with safety equipment like this are fixed free of charge by Nissan. bud
Return to “2nd Generation Altima Sedan (1998-2001)”
