Well, I just finished RE-Routing the wiring for my pillar gauges cause they melted on me when I ran OPEN dump on my wastegate...DONT ASK, ITS A LONG STORY, JUST TAKE MY WORD FOR IT..!!Anyways, it was fine b4 i re-did the wiring, once I got done, i cranked up the car and noticed that the light was blinking. Checked the fuse for continuity and it tested fine. I also notcied that when i removed the fuse, the light stayed on solid. I put the fuse back in, then the light started blinking again.I went and double checked the route of the wiring for the gauges and i didnt see any harness' that i may have opened cause it was in my way. I didnt cut anything from under the dash. All the wiring is in FLEX LOOM.. so there is no spagetti mess of wires.I dont know why its now blinking..
Anyone have this problem b4..?? Can someone tell me if there is a main harness for both air bags that i can check or where the wiring is routed thru...
ThanksRobert98 240sx SE
