DKing86 »
https://forums.nicoclub.com/dking86-u6802.html
Sun Apr 27, 2003 8:21 am
I didn't use the consult, I just followed the procedure to get the system into the diagnosis mode and counted the number of flashes and flash pattern. e.g., 3 seconds on 2 seconds off. This indicated that no malfunction was detected or that the problem is intermittent. When I returned the car to user mode and started it the light stayed out.
One thing to note is that when I did this the first time and did NOT start the car the light was flashing when I started the car later. I later read online that you have to start the car and that seem to fix the problem. I don't if this has anything to do with it...the book only said to do everything with the ignition switch in ON.
